Old 05-22-2011, 11:58 AM   #1
bronsin
bronsin's Avatar
A 6 speed transmission is NOT necessarily better for mileage. It all depends on the ratios. If 5th and 6th are numerically the same a six speed will use MORE gas! You have one more gear to accelerate in. The ideal would be a three speed with numerically identical 3rd gear to a five speed 5th. It would work here in flat NJ but probably not in hilly country.
SIx speeds and even five speeds are stupid consumer driven idiot inspired devices. Auto trans are similiarly going through the idiot process of more and more speeds.
Old 05-22-2011, 01:55 PM   #2
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
I disagree. In some cases it is not necessary, but in these times when you want to eek out as much gas mileage as you can, the right gearing on a 6 speed will help tremendously.
To the Op, there is a 6 speed that fits, but If I remember the final drive might have been numerically lower, meaning it would get worse gas mileage. If you could swap the Echo's final drive in that woud be much better for gas mileage. Not sure how much that would cost though.
Colin Chapman disciple
Old 05-22-2011, 02:35 PM   #3
bronsin
bronsin's Avatar
The right gearing...would help no matter how many speeds...
Old 05-24-2011, 07:09 PM   #4
why?
why?'s Avatar
Drives: Yaris LB
obviously, and we don't have the right gearing with the stock transmission. You just get a wider spread of better with more gears.
Yaris vs MR2 Spyder regal Off-topic / Other Cars / Everything else Discussions 36 01-25-2026 12:56 PM
Yaris TS 1.8L History and Specs CASTREX Yaris TS Talk 52 10-27-2009 05:06 PM
What the Yaris community needs to take the Yaris to the next level regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 124 04-30-2009 02:03 PM
