Old 05-27-2011, 03:03 AM   #1
Mister Z
Drives: 08 Yaris HB
how soon will this be available? and will this fit the 09+ yaris without modification? I know the NST ssk needs to be slightly modified to fit an 09+ yaris.
Mister Z is offline   Reply With Quote
Old 05-27-2011, 01:26 PM   #2
RedRide
RedRide's Avatar
Actually, this is not entirely true.
The probelm is, starting in '09 Toyota used two different vendors for the linkage that the SS mounts on.
Depending on which vendor they used, you might have to use a file or dremel to make it fit as the two linkages are slightly different from each other.
This is due to the hole for the cotter pin is not always %100 clear and able to accept the pin easily because the SS sits a hair higher on the stock linkage pin. Even then, the hole is still always visible.
On some with the linkage in question, all it takes is to gently tap the pin in once started in the hole.
In any event, it ony takes a minuite or two with a file to rectify this and it's no big deal.
IMO a newly designed/marketed SS should have been be machined to fit all '09 + linkages as the differnce between the two is extremely slight. Perhaps even a very thin shim could be supplied for use with older/other particular Yaris that need it although a shim would probably not even be nessary.
TWM Shift Knob SALE Until July 15th! TWM Performance Sponsors Classifieds Area 6 10-30-2009 12:46 PM
NEW GROUP BUY: NST Short Shift Kit (NonStopTuning) NonStopTuning NonStopTuning 245 08-28-2007 03:53 PM
short shift: NST or TRD? cali yaris Performance Modifications 21 07-07-2007 03:38 PM
Feb Shift Knob Sale From TWM! TWM Performance Sponsors Classifieds Area 2 02-18-2007 10:15 PM
Having Trouble with TWM Short Shift Install. Need Help xfatefailsx07 Performance Modifications 3 10-10-2006 01:38 AM
