Old 05-27-2011, 05:06 AM   #1
Beyond
Drives: 2004 xB
Best way to start?
Hi all.. first time posting here, I've got a 5spd 2004 xB that's got the same 1.5L engine as the Yaris and finally I'm looking into bumping up the performance a notch. I live in a mountainous area so any added power in 2nd gear would really be appreciated.
CAI , 1ZZ-FE Throttle Body swap, Header, Exhaust... which one should I start first?
Any combos of parts that work particularly well together?
It's a newbie question for sure, but I'd hope those of you who has gone down the performance route and tried different product combo can recommend your preference, and of couse any personal nuggets of wisdom.
Thanks in advance
Beyond is offline   Reply With Quote
Old 05-28-2011, 01:17 AM   #2
str8Yaris
str8Yaris's Avatar
Drives: Yaris Sedan Supercharged
Idk... but I would start with the cold air intake first.... that's the most easy way to start...... the just start heading towards the back..... u want to get the headers & performance exhaust after let the car breathe ...... u don't want pop in the 1zz & not have anything to really let that air out... u need good back pessure on your car if u want it to perform...... u want the air to get out as fast as possible. Usually ppl throw the 1zz when they have most of there mods already & want more power.... Idk that's my opinion, ppl can beg to differ.... everyone works on there cars different. Happy Modding
Thanks in advance
Blitz S/C @ 9psi
Vegas meet 2011
http://youtu.be/1IEebCmtvP0
str8Yaris is offline   Reply With Quote
Old 05-28-2011, 09:54 AM   #3
Calogero
Calogero's Avatar
Drives: Toyota Yaris
Thumbs up no replacement for displacement.....
save your money....rear sway, springs, brakes, shift kit and lastly and most important tires and wheels.... but you want more... build one... 2zr-fe 1.8l for $600 port+polish, light flywheel and turbo with LSD and proper bracing IMO... or else if it is just joy of moding... then choose what you like but understand what each mod does.
Lead, Follow or get out of way.
Thomas Paine
Stage One Yaris
TRDsway bar, TRD springs & shocks, TRD
Quick shifter kit, TRD CAI, TRD oil & coolant cap
Microimage light crank pulley, Agency Power steel braided brake lines.
Calogero is offline   Reply With Quote
Old 07-05-2011, 12:26 PM   #4
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
NO! back pressure of any form is bad.
the stock xB exhaust is 1 5/8" in diameter, its retarded small for performance use. I had made my own full 2" mandrel-bent exhaust on my '06 xB i had & it really liked it.
Get an intake, header (i have a JDM header i'm trying to get rid of) & a real full exhaust with a true high flow metallic core catalytic converter, axle-back exhaust only free up 1-2whp, so don't waste your time
thats enough to make a noticeable difference that you will feel & enjoy
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-04-2011, 04:15 PM   #5
TRDblueyaris
Drives: 08 liftback 5 speed
mine's stock except for a k&n filter and a trd quickshifter. plenty quick on city streets and handles well. trying to preserve my gas mileage.
TRDblueyaris is offline   Reply With Quote
Old 07-04-2011, 06:36 PM   #6
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
A CAI gives you the best bang for the buck. Well, for our gen motor it is anyway. (cable throttle)
Old 07-04-2011, 11:57 PM   #7
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
That also depends on which one you pick up on how much you will notice for a difference.
Old 07-05-2011, 02:23 AM   #8
EPyarisdriver
...or Vegas for short
EPyarisdriver's Avatar
Drives: 2010 Toyota Yaris 3door LB
For me I justput in my Tein springs and i love them. the car is so much quicker around the turns and i just feel more in control. plus in in 2nd gear when I turn... Bu if you want engine im thinking a CAI would work the best... thats my 2 cents!! Have fun
EPyarisdriver is offline   Reply With Quote
Vibration on idle & rough start Murtaza_murti DIY / Maintenance / Service 25 08-15-2015 12:58 PM
push start vs electric start? yaris2010RS General Yaris / Vitz Discussion 18 04-07-2010 02:20 PM
Car wont start - help! tamo300 General Yaris / Vitz Discussion 14 03-23-2010 10:44 PM
Yaris does not start jake002 DIY / Maintenance / Service 21 01-05-2010 08:53 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
