Old 05-27-2011, 09:15 AM   #1
swidd
Drives: Yaris HB
I got b-quiet for much cheaper than dynamat on eBay, its by most measurements the exact same material. It takes about 100 sq ft. to do the whole car. You don't have to do solid portions under the rear seat (no vibrations there). Suppose you don't have Home Depot, but dirt cheap rubberized roof insulation material will do the same job.
For heat problems, look into the A/C low pressure return line insulation mod.
swidd is offline   Reply With Quote
Old 05-27-2011, 04:14 PM   #2
BLOODY_STONE
Drives: 2009 toyota yaris 1.3 sedan
Ya i'm studying that mod r8 nw cuz someppl told me it can cause ur compressor to die out shortly!
BLOODY_STONE is offline   Reply With Quote
Old 06-10-2011, 09:23 AM   #3
mhkritzinger
Drives: 1.8 3dr Yaris TS
I also am planning to do what you did on your Yaris! Just wanna know if you only put the b-quiet on the outer skin of the door or did you put it on the inside skin and outer skin of the door here the speaker is??
mhkritzinger is offline   Reply With Quote
Old 06-10-2011, 02:33 PM   #4
swidd
Drives: Yaris HB
I only put it on the outside skin, because I didn't have anything to create a wall to cover the open gaps on the inside. I should probably go fix that.
Just covering the outside makes the door have a "luxury clunk" when it closes.
Sound when making a left turn (a water flow sound) jimmydie DIY / Maintenance / Service 9 06-20-2013 05:35 PM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-04-2011 11:56 PM
Yaris with new audio DPS module installed - Gadget or really increasing sound quality Flyingmatdes New YARIS Purchase Forum 8 04-19-2011 12:50 AM
New Sound System - Sound Issues click.mine In Car Entertainment + Electronics (audio / video / alarm) 11 03-20-2009 03:11 AM
DIY Sound Insulation Guide? qwerty123321 DIY / Maintenance / Service 4 02-07-2009 02:56 AM
