Old 05-27-2011, 12:25 PM   #1
regal
Drives: 09 Yaris 3 Dr White LB
Small bulb inside headlamp 09
My yars has a small bulb to the side of each main headlamp. I can find no info on this in the 2007 manual and no part numbers online. I need a new one, can anyone recommend a part number/supplier?
regal is offline   Reply With Quote
Old 05-27-2011, 12:56 PM   #2
It's a 192 12V 5W bulb.
http://www.oereplacement.com/partInf...ar=&eyear=#top
Old 05-27-2011, 01:45 PM   #3
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
im running camry visor bulbs which are 8 watts each. 90981-11062
ROCKLANDTOYOTA is offline   Reply With Quote
Old 05-27-2011, 11:08 PM   #4
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
I saw it listed as a 168 in a search of the forums.. CT?
Old 05-28-2011, 02:42 PM   #5
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
+1
http://www.sylvania.com/ConsumerProd...RG-Results.htm
OTA'sTOY is offline   Reply With Quote
Old 05-28-2011, 04:22 PM   #6
RedRide
RedRide's Avatar
Either 168, 194, or 192 will work fine
Personally, I'm partial to "Polarg B1 Hybrid M-4" bulbs which are listed as 168/194 and are 5w.
They are super long lasting hyper white bulbs and look great with hyper white headlights.
I've been using them for almost 10 years years in my Toyotas.
However they are a bit expensive but, worth it IMO.
BTW, I also have one in License plate light.
I experimented using various LEDs for the LP but, none gave me the wide dispersion pattern like a regular bulb does in that app.
Old 05-29-2011, 02:19 AM   #7
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
just look for an LED replacement. I got some for my bike and it makes the headlights white like HIDs.
Old 05-29-2011, 11:10 PM   #8
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
+1
I bought a pair of LEDs to replace mine -- they can get bright amd make the inside of the headlights 'glow' at dusk or when raining.
-toy
Replacing headlight bulbs nsmitchell DIY / Maintenance / Service 47 02-14-2016 10:07 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 02:50 AM
Removing plug on headlight bulb..... RedRide Cosmetic Modifications (Exterior/Interior) 9 12-28-2010 07:52 PM
One filament in the headlamp bulb. ellenbetty General Yaris / Vitz Discussion 7 09-06-2009 02:30 PM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 07:17 PM
