Old 05-30-2011, 10:34 PM   #1
heeroyuy01195
Post count means nothing.
Any Toyota/Lexus/Scion dual squib airbag will work. If you find a wheel with a single squib airbag, then to use it you would have to connect a 3ohm resistor across the second airbag connector to keep the SRS ECU happy.
Scott, thanks a bunch for that bit of information; that really helps a lot. When I eventually get my hands on the wheel do you mind if I shoot you a PM when I do the installation? I'll be putting up a full write-up when I get around to doing this.
edit: I know this might be a bit late but...will I need to do anything to get the horn to work?
Old 05-30-2011, 11:36 PM   #2
Definitely hit me up if you have questions. The horn will connect the same.
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
