The more timing advance you have in the ignition the higher grade of fuel you need. The 1NZ has a very conservative timing advance compared to the Civic SI and that's mostly why it needs high octane fuel.
If you were to run a stand alone EM and bump the timing up on a stock motor, you'd gain a bunch of power but you'd also require high grade gas. |
#2 | |
![]() Drives: 2010 Liftback Join Date: Apr 2011
#3 | ||
Only Happy When it Rains
And yes, i am almost positive none of the boosted guys have lowered compression.
Colin Chapman disciple |
^ Garm and Parmas are the only ones.
I actually only run 89 now with no issues. It's incredibly unlikely the noise is actually pre-detonation. |
Well I haven't heard any pinging sounds since switching to 93. Would there be anything else that would make a pinging like sound that would improve by switching to a higher octane fuel? I'm wondering if the ethanol is having an affect on the octane rating?
ethanol does have an effect on the octane rating, it makes it higher.
| Pinging noise coming from the front right | hachi-roku_fan | DIY / Maintenance / Service | 3 | 01-24-2011 04:41 PM |
| Knocking / Pinging | TDaniel | DIY / Maintenance / Service | 11 | 04-08-2010 06:12 PM |
| Pinging belt when wet or cold | steveh74 | Europe (continental) | 0 | 08-22-2009 05:50 AM |
