The Yaris spring shocks are 6" stroke, 17" extended mounting center line, 80 lb (359N) gas shocks with ball socket ends. Doing a quick web search based on those measurements, I've seen generic replacements for as little as $15 each.
I am tempted to upgrade to 100 lb or 150 lb ones (which are common ratings) too see if it helps with the winter sag. One evening this past Winter In a dark parking lot I whacked my head so hard that I drew blood.
#2 | |
advocatus diaboli
I did the same thing in my garage the other day because the damned hatch was sitting a little lower than normal(I didn't help it up the last little bit). I didn't draw blood, but it hurt enough that I had to stop what I was doing for a minutes and curse the heavens. Now that I've sound deadened the hatch it's a little heavier, which in turn has made it open even less... I'd be interested in a part number if you decide to swap in something more powerful, and it works.
#3 | |
JOE GIRTH
Drives: YARIS 3DOOR Join Date: Feb 2007
#4 | |
This place sells the 010-170 for $18 each: https://www.makariosrv.com/products/...-Products.html Here's a pair of 120 lb ones for $30 (and the same vendor also carries 101 and 110 lb ones for the same price): http://cgi.ebay.com/ebaymotors/ws/eB...em=#vi-content
| Where can i get a Hatchback trunk cover for cheap? | Syroyizhka | Cosmetic Modifications (Exterior/Interior) | 19 | 10-29-2013 12:59 PM |
| 3 Door Hatchback Questions | Dorkinheimer | General Yaris / Vitz Discussion | 12 | 01-16-2012 05:30 PM |
| Hatchback Trunk Cover | KrazyDawg | General Yaris / Vitz Discussion | 24 | 11-08-2010 02:00 AM |
| is this trunk kit ok for our hatchback ?? | vten | DIY / Maintenance / Service | 3 | 10-31-2009 02:49 AM |
| yaris sedan remote trunk relase question pls help soon | fantabulousbaby | New YARIS Purchase Forum | 4 | 08-05-2006 01:26 AM |
