#19 |
Not quite a noob
Any update CT?
#20 |
They haven't arrived yet.
Yesterday though, I was helping enviri wire up one of my Push to Start modules and his xD turn signal mirrors on his 2010 LB and I happened to mention the whole hatch sag issue. He said that he doesn't have the issue, so we compared his hatch to mine. His pops up into the fully open position, where mine slowly moves to about 3/4 of the way up. I realized that mine used to move the way that his does, so just replacing them with the standard would probably be fine, but I will still try the 101's once they arrive.
#21 |
Not quite a noob
I'll still wait for your results for a better decision.. thanks!
#22 |
I received the new 101 lb ones yesterday (8 days from order to receipt). I installed them this morning (it literally takes less than 1 minute per side to replace them). The new ones make a huge difference. The 101 lbs of lift make the hatch pop all of the way open very quickly (to the point where there is a little bounce at the end of travel). I will post a video comparison later, but here's a photo of the new ones vs. the OEM. The shaft is stainless steel on the replacements, whereas it was painted on the OEM ones.
#23 |
Not quite a noob
Excellent. If they fit then I'll grab a pair for myself
EDIT: I'll wait for a video though- and whether my pack mule in the states is coming up to Canada this weekend so I don't have to pay as much for shipping ;) |
#24 |
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
CTScott,
Is it still relatively easy to close the hatch with the beefier cylinders? Thanks, R2 |
#25 |
![]() ![]() Drives: 2007 LB Join Date: Jan 2009
Is this the right set for the 101 lbs? http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
Hope so cuz I bought a set today. |
#26 |
Not quite a noob
I believe that is the right set yes. I'm just waiting for CT's video before I buy.
#27 |
You just don't want the door to fly open fast enough to eventually tear out the mounts!
#28 |
Not quite a noob
#29 |
I ordered a set. Heck for under $40 I'll take the gamble. I'm in NY so I had to pay the sales tax and it better not take 8 days in state to ship, I hope! I'll ask CT how you get them off and on..CT?
#30 |
Yeah, now I'll have to leap back vs. being hunched over to not get hurt...
#31 |
Not quite a noob
I'm eagerly anticipating his video.. I hope he took a before and after!
#32 |
Here's the video comparison of the work out OEM ones vs. the aftermarket 101s:
http://s372.photobucket.com/albums/o...Comparison.mp4
#33 |
Holy crap! The whole back of the car rises! No more helping up that door anymore. Can't wait to try mine out when they come....
Thanks for coming through with that real pro lookin' vid too!
#34 |
In the before video, my hand is cut-off after initially opening the hatch, but each time time there is a pause, I then push the hatch open a bit more.
The new ones are definitely a bit more potent than necessary, but I suspect that after a couple of weeks they will calm down.
#35 |
I plan to open the hatch then "follow" the door as it goes up to avoid tearing out the mounts. A guy on here is a courier in the UK I think and did that from opening his hatch so many times daily as part of his deliveries.
Now imagine if you had gotten the even more powerful ones????
#36 |
To swap them out:
1. Prop the hatch fully open. I used a fiberglass painter's pole. hatch prop.jpg 2. Using a small flat-blade screwdriver, pry the clip up about 1/8" (you don't need to fully remove the clip). 3. With the clip up, pull the end off of the ball. 4. Do the same on the other end of the gas spring. 5. Pry up the clips on the new one. 6. Slip the bottom onto the ball (the bottom is the larger diameter end). 7. Rotate the top (clockwise) until it lines up with the ball and slip it on. 8. Push the clips back down. 9. Repeat on the other side.
| Where can i get a Hatchback trunk cover for cheap? | Syroyizhka | Cosmetic Modifications (Exterior/Interior) | 19 | 10-29-2013 12:59 PM |
| 3 Door Hatchback Questions | Dorkinheimer | General Yaris / Vitz Discussion | 12 | 01-16-2012 05:30 PM |
| Hatchback Trunk Cover | KrazyDawg | General Yaris / Vitz Discussion | 24 | 11-08-2010 02:00 AM |
| is this trunk kit ok for our hatchback ?? | vten | DIY / Maintenance / Service | 3 | 10-31-2009 02:49 AM |
| yaris sedan remote trunk relase question pls help soon | fantabulousbaby | New YARIS Purchase Forum | 4 | 08-05-2006 01:26 AM |
