Old 06-10-2011, 09:23 AM   #6
mhkritzinger
Drives: 1.8 3dr Yaris TS
Originally Posted by swidd View Post
I got b-quiet for much cheaper than dynamat on eBay, its by most measurements the exact same material. It takes about 100 sq ft. to do the whole car. You don't have to do solid portions under the rear seat (no vibrations there). Suppose you don't have Home Depot, but dirt cheap rubberized roof insulation material will do the same job.
For heat problems, look into the A/C low pressure return line insulation mod.
I also am planning to do what you did on your Yaris! Just wanna know if you only put the b-quiet on the outer skin of the door or did you put it on the inside skin and outer skin of the door here the speaker is??
mhkritzinger is offline   Reply With Quote
Sound when making a left turn (a water flow sound) jimmydie DIY / Maintenance / Service 9 06-20-2013 05:35 PM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-04-2011 11:56 PM
Yaris with new audio DPS module installed - Gadget or really increasing sound quality Flyingmatdes New YARIS Purchase Forum 8 04-19-2011 12:50 AM
New Sound System - Sound Issues click.mine In Car Entertainment + Electronics (audio / video / alarm) 11 03-20-2009 03:11 AM
DIY Sound Insulation Guide? qwerty123321 DIY / Maintenance / Service 4 02-07-2009 02:56 AM
