Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 06-11-2011, 07:48 AM   #1
rosco
rosco's Avatar
Drives: YaRis ka!--Y?2011
Originally Posted by syntax View Post
@ duke, painted na ba ang calipers mo at drum brakes?
pre pagnagpatimpla kayo..pakisuyo naman ng bloody red ..ha abot ko na lang bayad....para sa engine ,fuse cover at sa tow hook ko...
TIA.
rosco is offline   Reply With Quote
Old 06-11-2011, 07:55 AM   #2
fgorospe76
"i R i S H"
fgorospe76's Avatar
Drives: Toyota Yaris 2010
Originally Posted by rosco View Post
pre pagnagpatimpla kayo..pakisuyo naman ng bloody re ..ha abot ko na lang bayad....para sa engine ,fuse cover at sa tow hook ko...
TIA.
matanong ko lang po..magkano ba patimpla?
fgorospe76 is offline   Reply With Quote
Old 06-11-2011, 07:56 AM   #3
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
tol 20 - 35 SR. depende sa dami at kulay.. ung primer para sa plastic at top coat no idea.. syntax passooookkkk
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 06-11-2011, 07:59 AM   #4
fgorospe76
"i R i S H"
fgorospe76's Avatar
mura lang pala tol, ang problema ung pambuga na lang hehehe
Old 06-11-2011, 08:10 AM   #5
syntax
syntax's Avatar
wehehehe hindi ko na rin tanda eh, may memory gap na, si jonimac ang nag kwenta noon eh, sa primer ay 20 lang ata at ung top coat nasa 25 ata, ( marami na ito, kasya sa apat na bugahan)
Old 06-11-2011, 08:07 AM   #6
syntax
syntax's Avatar
TIA.
cge pre mukhang pwede ako mamaya after work, daan ako dun.
Old 06-11-2011, 08:12 AM   #7
duke_afterdeath
tol wag ka muna patimpla mamaya kasi walang talyer sa friday baka matuyo lang.. rest muna daw sabi ni ka bong
Old 06-11-2011, 08:15 AM   #8
rosco
rosco's Avatar
ok ....pre wag daw muna...baka sa esteraha na lang sana matuloy.
Old 06-11-2011, 08:19 AM   #9
syntax
syntax's Avatar
ok pre' noted buti nasabi agad ni duke'
Old 06-11-2011, 08:19 AM   #10
syntax
syntax's Avatar
pre wala ba? pano un sendong? next time na muna? or tuloy?
Old 06-11-2011, 08:20 AM   #11
rosco
rosco's Avatar
next friday na lang wag this coming friday kasi papalagay din ako ng ilaw sa hood at yung tukod......pahinga muna si manong bong...napapagod din sila
Old 06-11-2011, 08:13 AM   #12
rosco
rosco's Avatar
salamat ha.....basta complete set na yung primer at top coat?..basta bahala ka na.....
