![]() ![]() Drives: 2009 toyota yaris 1.3 sedan Join Date: Apr 2010
increasing sound insulation?
HAI GUYS
i'm really sick of driving in the HOT & CROWD roads of Egypt .. I want to increase the sound (and heat if possible) insulation in my babe yaris ![]() Any suggestions? or cheap ideas? |
![]() ![]() ![]() Drives: Yaris sedan Join Date: Apr 2011
The cheapest option is a standalone installation of insulation.
For good materials vseravno have to pay. |
k somebody tell me whati should get?
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
I got b-quiet for much cheaper than dynamat on eBay, its by most measurements the exact same material. It takes about 100 sq ft. to do the whole car. You don't have to do solid portions under the rear seat (no vibrations there). Suppose you don't have Home Depot, but dirt cheap rubberized roof insulation material will do the same job.
For heat problems, look into the A/C low pressure return line insulation mod. |
#5 | |
#6 | |
![]() ![]() Drives: 1.8 3dr Yaris TS Join Date: Nov 2008
#7 | |
Just covering the outside makes the door have a "luxury clunk" when it closes. |
I thick coat of rubberized undercoating in the wheel wells makes a BIG difference. Very cheap project too!
Bronze bombshell yaris
Drives: 09 Yaris HB 3door Join Date: Sep 2010
I just looked on ebay. I wish that b-quiet stuff wasn't so pricey, I don't even put $2.50/sqft flooring in my house, much less something that goes unseen in my car. heh
Now I drive a CARMINE RED METALLIC 09 Yaris 3-door!! I'm Back!!! WooHoo!! Mods done so far: Tinted windows, Viper 211HV Remote Keyless Entry, Atoto Android headunit, backup camera, steering wheel controls Before it was totaled I drove a 2007 Black Sand Pearl 3 Door Lift-Back M/T with 49k miles. Stock Everything except for black tint, all red badges, red dash, and stealth garage door opener. Ultra-Gauge mounted on steering wheel. A1 Electric MES Central Locks and Avital 3100 Alarm system.
Then head to Home Depot =)
can anyone tell me if their is an cheaper alternative to dynamat or b-quiet?? I really wanna do this to my car! and how do you close the holes inside the door? and the rubberizing of the wheel wels what kind of product can i use to do that?
wheel wells: rubberized undercoating / truck bed rubber spray. Someone also sells a anti-corrosive dense paint that you'd need multiple layers of. As cali_yaris said, it absolutely helps; I've applied more and more to finish off my sound deadening project - it isn't good enough to be the only solution, but fixing the wheel wells make a big difference in tire and rolling noise.
home depot: peel & seal. Anything that looks like it is made of rubber/a tar base dense flexible "asphalt" on one side, with fixed aluminum backing. Should also be pre-glued so it is less mess. Make sure it actually isn't asphalt... |
![]() Here are 29 photos on soundproofing. |
#14 | |
I will head to the home depot and get that stuff. will you be able to hear the difference between dynamat and something like this? THanx for your help! I appreciate it!! |
#17 | |
#18 | |
The difference between dynamat and b-quiet or peel and seal is not appreciable. The material is essentially the same, short of a few m.m. difference in thickness. As your stuff will be way cheaper, you can just do double layer in the middle sections of the surfaces you cover. It has nothing to do with the material really - dynamat for $600 isn't magic or superior - it is all about adding mass to prevent the sheet metal from vibrating, while getting a good glue that will permanently stick even in rain, sun, winter and extremes of either. Use a roller to press the stuff into edges and get a good stick. I think good results are more about patient and thoughtful install than thickness of the material. If you want it even more quiet, get foam, like a foam mattress, and stuff it into the door frames. |
| Sound when making a left turn (a water flow sound) | jimmydie | DIY / Maintenance / Service | 9 | 06-20-2013 05:35 PM |
| 2008 Yaris sedan ‘S’ sound deadening project. | Herbicidal | In Car Entertainment + Electronics (audio / video / alarm) | 155 | 09-04-2011 11:56 PM |
| Yaris with new audio DPS module installed - Gadget or really increasing sound quality | Flyingmatdes | New YARIS Purchase Forum | 8 | 04-19-2011 12:50 AM |
| New Sound System - Sound Issues | click.mine | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 03-20-2009 03:11 AM |
| DIY Sound Insulation Guide? | qwerty123321 | DIY / Maintenance / Service | 4 | 02-07-2009 02:56 AM |
