Old 06-13-2011, 06:08 PM   #1
hayden
Drives: asd
It's an AT 2007 2 door.
If there was no connection at all to the ECM, would that line still be powered? I'll go reseat the pin and see if that helps because it was definitely intermittent before dying entirely.
hayden is offline   Reply With Quote
Old 06-13-2011, 06:26 PM   #2
That wire would be zero volts if disconnected. But, it could be connected when still and intermittently disconnected when the engine starts shaking it.
Old 06-13-2011, 06:47 PM   #3
hayden
Drives: asd
Reseated the pin, no luck. I'll try going out there and wiggling it while taking a reading to see if I can make it go to 0. Any other advice if that shows up fine though?
Old 06-13-2011, 06:52 PM   #4
If that looks solid, work your way towards the stalk, verifying the connections along the way.
