Old 06-15-2011, 11:17 PM   #1
aznofmuff
Drives: yaris08
hey guys!! thanks a lot for all your suggestions. but i tried jump starting the car, checking the fuses and everything but it still doesnt wanna start. theres no cranking sound from the starter motor when i turn on the engine. i kinda hit the right front side of the yaris and the radiator was bent in by like 10 cms. I still got no idea of how i can get the old girl running again. when i start the key the check engine, check oil and battery lights stay on. I also tried a scantool on it but theres no codes. thanks in advance!
aznofmuff is offline   Reply With Quote
Old 06-16-2011, 12:26 AM   #2
The lights stay on until the ECM gets the "start" input. If you have a multimeter, the next thing to do is to start following the flow of current to see where it stops.
First: At the ignition switch connector, measure the voltage on the gray wire (with the ignition off)
