Old 06-17-2011, 07:15 AM   #1
Kongo-Otto
Drives: '09 Yaris & '10 Auris
Originally Posted by auxmike View Post
Bear in mind it will increase interior cabin noise too.
Thats it. These parts actually reduce driving comfort. Of course it is no problem for a race car but i would not mount these in a daily driver.
Old 06-17-2011, 12:34 PM   #2
Jason@SportsCar
That is usually only the case with a poor quality bearing, or if the shock or mont is a poor fit.
I have experienced both over the years. This will be the first Cusco part I have ever used, but so far they look like good parts.
Old 06-17-2011, 02:09 PM   #3
Kongo-Otto
Has nothing to do with the bearing. The rubber part is there on street cars for some good reasons, i.e. isolation (or decoupling?) and less stress for the monocoque. I don't know all the words in english. Sorry.
I had a solid mount at my Toyota Starlet many years ago. Vibrations and any other noises from the suspension and tires have been significantly louder inside the car.
You don't need comfort in a race car and you don't like the side effects of a rubber mount in a race car, too. Thats for sure. And of course a race car usually has many bars to stiffen up the body. Cusco is known for high quality parts, i had some braces from them at my Starlet. Any part was a perfect fit and had flawless engineering.
Old 06-17-2011, 02:54 PM   #4
Jason@SportsCar
I had Moton suspension with solid mounts and bearing on my daily driven RX-8, no issues what so ever. Using quality parts means a lot. Bearings have gotten a bad rap over the years because some companies use low quality parts, a sloppy or loose bearing is a great way to pick up noise. Parts that are tight and move smoothly force the shock to do its job.
Old 06-17-2011, 02:58 PM   #5
Jason@SportsCar
And they fit.
Old 06-17-2011, 04:21 PM   #6
jekqmb
Local Sh*t Disturber
Drives: 2009 Yaris LB
Nice Jason, looks great!
Adjustment to the upper shock mounting point? Goose Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 06-07-2010 03:41 PM
need measurements of 2009 3dr upper grille blacksandiegovitz Cosmetic Modifications (Exterior/Interior) 2 11-30-2009 10:37 AM
FS: Garmin GPS Unit w/ ProClip Mounts, 180mm Double Din Trim Piece IsLNdbOi Items for Sale by private party 2 08-23-2009 02:37 AM
In need of upper and lower grilles and upper grille cover bam2626 Items for Sale by private party 2 06-25-2009 10:34 PM
DIY: Urethane Engine mounts turboyaris DIY / Maintenance / Service 1 05-21-2007 01:08 PM
