DAT'S RIGHT I GOTz 2
I just recently purchases a 2007 Certified Toyota Yaris 4 Door Sedan manual.
--how long ago? I have driven a manual since I turned 16 --how old are you now? and am experiencing a problem I have never encountered. --how many previous and what kind of cars did you own/drive prior A/T? M/T? When coming from a start (typically after starting the car) and starting out when I'm about half way released from the clutch in 1st I notice a clunking sound? --does this happen only when pulling out in first gear ? Any suggestions as to why?? --could be a number of things i.e. bad motor mount(s),play/bad (in) swaybar endlink(s),etc if you purchased this recently as you stated, take it back to where you got it from and voice your concern unless you bought it "as is". if so look into a reliable repair shop
#2 | |
![]() ![]() Drives: 2010 5 Door Join Date: Jan 2011
I bought a 2010 new off the lot and it does the same thing. Its just the clutch grabbing. All the manuals on the lot did it, a yaris thing id imagine. I brought it up on the test drive and they pulled it into service. The techs said it was just the clutch engaging. |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
Yeah, due to the motor mount design, the motor moves a lot when you dump the clutch.
| Tags |
| clunking sound |
| Front End Clunking Sound when hitting small bumps | Arizona_Commuter | DIY / Maintenance / Service | 16 | 06-17-2011 11:32 AM |
| clunking sound | 3stars_n_a_sun | General Yaris / Vitz Discussion | 7 | 03-11-2010 07:57 AM |
