Old 06-19-2011, 05:56 AM   #1
Kongo-Otto
Drives: '09 Yaris & '10 Auris
What happens if you lift the car with a service lifter? Will the springs fall out of their seats? I guess they will atleast at the front and thats one reason why cutting springs isn't very recommandable. With that amount of lowering and stock shocks you will ride on your bumpstops all the time, another reason.
Old 06-19-2011, 08:57 AM   #2
20104dr
CLIFF
20104dr's Avatar
Drives: 2010 4dr
Yes they do fall out of the seats. You just have to be there when they bring car down to make sure they go back in correctly. As far as bumpstops, i of course cut them in half. This not my first rodeo in slammin vehicles. Bottom line is i dont mind some of the inconviences that come along with being LOW and looking good. Thanks for your opion though!!
"who the cap fit let them wear it"
20104dr is offline   Reply With Quote
Old 06-24-2011, 01:22 PM   #3
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Ok, I dont want to get in another pissing match. BUT jekqmb is right about handling, and I am only touching on the handling point on this.
Im quoting this because if you actually track a car or even autox a car that have cut springs, you will taking turns at full braking and quite possible tripod (3 wheel on the road, 1 rear wheel in the air).
So if you have to be careful about bringing a car off a jack or a lift and make sure that the spring seats inside the strut mount, you should be worried about taking those sharp turns on the on ramp with uneven roads and pot holes. You cannot tell me that cut springs are just as good as lowering springs and/or coilovers when it comes to handling.
Like I said before, to each thier own.
Cut springs are for showing off on a budget. Be careful driving out there and keep us posted if something should happen. I am curioius of the life of your shocks if you are still running stock ones. Your car looks good, I do like it. Kudos on your mods
Tein S-tech Springs with Stock shocks combination. daddz07 California 11 08-21-2010 01:49 PM
Tein S-tech Springs with Stock shocks combination. daddz07 Performance Modifications 1 08-09-2010 03:45 PM
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
