Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Central and South America
Old 06-25-2011, 12:55 AM   #1
Rodcom
Drives: Toyota Vitz 2006
If the 153 works that will be great, that one is a LSD!!
The transmission is an automatic that have a space on the shift trail that let you shift manualy (like audi triptronic) according to what I know that is a CVT stuff.
thanks again.
Rodcom is offline   Reply With Quote
Old 06-25-2011, 07:59 AM   #2
thanks again.
That type of automatic is not a CVT (continuously variable transmission), but rather a Multimode one. The Multimode one is a traditional automatic transmission, with a valve body that allows one to manually shift.
Here's a picture of a C153. It looks like the drive shaft would have to be shortened on the differential side. Besides changing the transmission, you would also need to change the shift and cables, add the clutch pedal and linkage, and change the ECM (since the Yaris ECM does the transmission control for AT cars).
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 04:48 PM
manual transmision problem parce1992 General Yaris / Vitz Discussion 9 02-16-2009 12:56 PM
