Your very welcome! That was by far the most interesting parts shipment I have ever done.
![]() ![]() Drives: '08 HB Join Date: Nov 2008
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
#4 | |
![]() ![]() ![]() Drives: US 2007 Yaris Liftback 5MT Join Date: Aug 2006
![]() - Jason
2007 Toyota Yaris Liftback Base 5 Speed. Mods: Netz/Vitz/RS badging, RS style spoiler, RS replica tails, Tenabe NT210 Springs, Tokico Blue Struts, Team Dynamics 14", fogs(Arrived), JDM HKS Exhaust. Last edited by Kiteless; 06-29-2011 at 11:18 AM. Reason: Missing tag |
#5 | |
![]() ![]() The transmission was off of a 2008 that only had 3,800 miles on it before the owner decided to try to pass a trailer truck by going under it. The car only had damage from the top edge of the hood and up, so the drivetrain was perfect. I have actually purchased a lot of parts off of the car, and even saw it running before the junkyard pulled the engine and tranny to put them on the shelf. The junkyard charged me $600 + sales tax, so I loaded it into my Xterra for $636. You can often pick them up for far less on eBay (as cheap as $250), but not with such low miles. I was originally going to ship it via UPS Freight and even spoke to UPS to get a quote and verify some things regarding the create. UPS quoted me a little over $500 to ship it. I had it crated and was ready to bring it to the UPS Freight depot and called them one more time to verify which airport in Moscow Mikhail would need to pick it up from. At that time UPS told me that due to Russian customs issues, they can not ship a freight item to an individual. It would have to go to a business and that business would have to do tons of paperwork to get it out of customs. So, thinking that we were dead in the water, I called USPS for the heck of it to see if I disassembled it into 70 lb parcels (the max weight for USPS) if they would ship it. The answer was not just "Yes", but that USPS has less issues delivering to individuals in Russia than they do to people in Italy or Spain. So, out of the crate it came. I then proceeded to disassemble it, literally on a freight scale, working towards getting the main body of the transmission to be less than 65 lbs, so that it plus packaging would equal less than 70 lbs. I ended up with three boxes. Box 1 of 3 - 66 lbs. 1. Toyota Yaris U340 Transmission Case Box 2 of 3 - 36 lbs. 1. Differential 2. Oil Pump 3. Input Shaft/Forward Clutch Hub Assy. 4. Oil Strainer Assy. w/screws 5. AT Oil Pan Assy. w/screws 6. Manual Detent Spring Assy. w/screws 7. Transmission Wire 8. Speedometer Sensor 9. Accumulator Pistons x3 10. Check Ball Assy. 11. Gaskets x4 12. Bell Housing Bolts x11 13. Oil Pump Bolts x7 Box 3 of 3 - 52 lbs. 1. Bell Housing 2. Torque Converter 3. Valve Body I took pictures of every step of the disassembly process and provided Mikhail with the attached detailed document on how to reassemble it. I learned a lot during the process and now am completely ready to install a limited slip differential in Crashy's automatic transmission. Toyota Yaris U340 Automatic Transaxle Assembly.pdf
#6 | |
![]() - Jason
2007 Toyota Yaris Liftback Base 5 Speed. Mods: Netz/Vitz/RS badging, RS style spoiler, RS replica tails, Tenabe NT210 Springs, Tokico Blue Struts, Team Dynamics 14", fogs(Arrived), JDM HKS Exhaust. |
| Problem with my car | rakhan01 | DIY / Maintenance / Service | 8 | 12-03-2010 05:12 AM |
| Toyota C160 Reverse Gear Problem | Parmas | DIY / Maintenance / Service | 2 | 12-01-2010 01:30 AM |
| Problem Starting Car | drunkwithwords | General Yaris / Vitz Discussion | 3 | 07-21-2010 04:01 PM |
| Yaris Central Locking Problem | pbasuita | UK | 0 | 07-10-2010 03:46 AM |
| Launching @ 4Krpm problem .... need tips | Parmas | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 12-30-2009 08:11 PM |
