Old 06-28-2011, 01:33 AM   #1
When was the last time you had an alignment done? If you haven't had one done, I'd get it checked out (the place that rotates your tires probably does alignments).
As for other maintenance, check your coolant level weekly (better if you can daily), and the same with your engine oil level. I'd check the other fluids at least once a month (better if more often). Check how dirty your air filter is, especially if you live in a dusty area. Replace if it's heavily soiled.
Old 06-28-2011, 04:57 AM   #2
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
+1
Also, is this a brand new car? How many miles are on it now? Toyota will do a complimentary free alighnment before it hits 15000 miles if you have an issue. Could also be that a front tire got separated. If you rotate the tires and it goes away, that could be the issue.
hold up. Is it wondering or pulling you left, right or both?
Could also be just the Highway. Road crown can cause this when people drive closer the the left or right of the white lines.
Old 07-06-2011, 12:20 PM   #3
localkineguy
Drives: 2003 Mazda Protege5
+1
localkineguy is offline   Reply With Quote
Side Airbags Yaris 2007 narkeeso DIY / Maintenance / Service 0 07-20-2010 02:15 PM
WTB: Front, Back, and Side Lip from yaris type-S Vinsanity Willing to Buy by private party 1 12-13-2008 09:58 PM
