![]() Drives: Blue Yaris Hatchback Join Date: Jun 2011
Trans Downshifts at weird times
Intermittently the (auto) trans will downshift at weird moments, such as going downhill at higher speeds. Is there a recall for the solenoids on the Yaris or is there a different problem (or just a design flaw)?
Not quite a noob
is it downshifting while you're still applying gas? If not, that's the engine gearing down to slow you on purpose.
No. I will be idling down hill, not at all applying the brake, and it will downshift. I just find it weird that this happens intermittently.
Not quite a noob
I don't think that's downshifting actually.. I think that's the DFCO kicking in. (Deceleration Fuel Cut Off). It's built in to help save gas.
#5 | |
![]() ![]() ![]() Drives: Polar White 2008, 3Dr HB TRD ' Join Date: Mar 2009
My car actually does the very same thing with auto trans. It appears that the computer knows when you are not applying any input to the accelerator pedal and as soon as you touch the brake pedal, the trans will automaticly downshift. It appears to be an aid in braking. It then stays in the downshift mode until you have applied acceleration input back to the ''go'' pedal for a period of about 10 seconds then it will shift back to high gear again. |
All newer toyotas have this feature built into the auto transmission programming. It's to help slow the car if you're off the accelerator and gaining speed. It even works with the cruise control set.
That's a good feature for brake assist, and or quicker acceleration, but it goes against fuel mileage, especially while going downhill.
Thanks for the replies btw |
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
Actually depending on the situation it can save gas because when no throttle is applied and you are engine braking down the hill the fuel injectors are not activated and no fuel at all is used.
If you want to keep momentum down a hill then ever so slight pressure on the accelerator will prevent DFCO/and the downshift. R2 |
It should really only activate when you push the brake pedal.
![]() ![]() ![]() Drives: US 2007 Yaris Liftback 5MT Join Date: Aug 2006
Does the Manual have this fuel cut off? I find that if I coast and downshift the engine braking on the Yaris is better than any other car I have ever ownwed. I always thought it was the compression, but its only like 9.5/1 or something right? 92K miles and still on my original brakes from the dealer.
2007 Toyota Yaris Liftback Base 5 Speed. Mods: Netz/Vitz/RS badging, RS style spoiler, RS replica tails, Tenabe NT210 Springs, Tokico Blue Struts, Team Dynamics 14", fogs(Arrived), JDM HKS Exhaust. |
Not quite a noob
Yes, the manual also has DFCO
That also explains the tone change of the engine when coasting, and again, brakes lasting FOR EVAR with my driving style.
- Jason
| Boosted Yaris Quarter Mile Times | 1.5 | Forced Induction Forum | 0 | 01-03-2010 05:49 PM |
| Auto trans : Drive to Park + Handbrake : was not in park... | Maxh91 | General Yaris / Vitz Discussion | 7 | 06-11-2009 06:37 PM |
| Effects of too much trans fluid in the case? (auto trans) | detroiter | General Yaris / Vitz Discussion | 5 | 02-24-2009 11:08 PM |
| Need pics of the yaris 5spd trans | Snake | Performance Modifications | 0 | 02-15-2007 11:04 AM |
| Maintenance - Change Auto Trans Fluid | Linkseal | DIY / Maintenance / Service | 1 | 08-15-2006 10:57 PM |
