Old 06-28-2011, 09:55 AM   #1
aznofmuff
Drives: yaris08
hey scott, i took off the starter motor and the solenoid, i put 12v to the starter and it works. but when i applied it to the solenoid nothing happens. is there a way that i can if the solenoid or the wiring to the solenoid is faulty? thanks in advance
aznofmuff is offline   Reply With Quote
Old 06-28-2011, 10:27 AM   #2
On the solenoid, measure the resistance between the pin that the violet wire connects to and the large bolt terminal. The resistance should be less than 2 ohms.
