![]() Drives: 2003 Mazda Protege5 Join Date: Jun 2011
Tires looked good when I took a look at them...they looked evenly worn too. The owner/driver is a manager (late 30s?) at a Harley Davidson store. Many miles were highway (so he claims) to commute to and from where he used to work.
How can you make sure the clutch is "in good shape" via a test drive? |
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
[QUOTEHow can you make sure the clutch is "in good shape" via a test drive?[/QUOTE]
Stop the car. Set the park brake. Put it in 5th gear. Rev the engine to red line. Pop the clutch while keeping the engine reved. If the engine dies, the clutch is good. If the engine keeps running, the clutch is bad. Note: Don't let the current owner see you do this test.
Making a decision without following it with an action is still a fantasy. Last edited by nemelek; 06-28-2011 at 07:51 PM. |
#3 | |
![]() ![]() ![]() Drives: US 2007 Yaris Liftback 5MT Join Date: Aug 2006
Also test brakes, does it stop well? Good, no need to slam on them. Also brake gently, any wobble? If there is there may be a warped rotor and at that age will need replacing. Look under the car, any oil? After it's warmed up listen to it idle, it should be niiiiice and smooth. Pop the air cleaner and look at it. Is it nasty? Even if it does not need it, maybe go get a test only smog done on it. If it passes, that is also a good indication that it is a solid running car. You can even put a volt meter on the alternator and see what its putting out. I believe a good strong alternator should put out like 14 volts? May need correction there. Thats my way anyway. I am too chicken***t to redline a car, especially someone elses. Hope this helps. - Jason
2007 Toyota Yaris Liftback Base 5 Speed. Mods: Netz/Vitz/RS badging, RS style spoiler, RS replica tails, Tenabe NT210 Springs, Tokico Blue Struts, Team Dynamics 14", fogs(Arrived), JDM HKS Exhaust. |
alternator voltage
1. Can you post a picture of the accessory belt? Is it the belt on the passenger side of the car?
2. Rotor warping shows up as vibrations in the brake pedal during deceleration right? (i.e. wobble = vibrating/pulsing?) 3. Can you also post a picture of the air filter? 4. Can I get a second opinion on the alternator voltage? I do have a multimeter and can do that pretty quickly By the way, thanks for all of the responses guys |
| Looking at buying a 2003 Yaris | TonyBee | UK | 8 | 03-31-2011 06:53 AM |
| Thinking about buying a 07 yaris sedan | brg88tx | New YARIS Purchase Forum | 14 | 06-28-2010 11:57 AM |
| Buying Yaris | stepish | Australia | 14 | 01-20-2009 10:11 AM |
