Old 06-29-2011, 12:04 PM   #1
aznofmuff
Drives: yaris08
hey scott, these are the measurements i recorded for the wires.
GREY [ 14.4v off, 14.4v on, 14.4 v start]
YELLOW [ 14.4 off, 14.4 on, 14.4 start]
BLACK [0v off, 0.01 v on, 14.4 v start]
PINK [0v off, 14.3 on, 14.4 start ]
WHITe [0 off, 14.33 on, 0 start]
GREEN [0 v off, 14.43 on, 14.43 start]
thanks!
aznofmuff is offline   Reply With Quote
Old 06-29-2011, 01:47 PM   #2
thanks!
OK - That is all correct.
What I would like you to do next is to swap two relays for me in the under hood fuse panel, to see if the ST relay is bad.
In the diagram below of the fuse box there is the "HTR SUB1" Relay and the *10 Relay (which is the "ST" relay). They are both the same type of relay, so you can safely switch them for a test. Swap them and then try to start it.
Name:  Yaris - Under hood fuse panel.jpg
Old 06-29-2011, 02:26 PM   #3
aznofmuff
Drives: yaris08
hey scott, i just went to look at the fuse book and i dont have the hrb sub 2 relay. just the st relay. i took the st relay to have a look and its got what looks like black ink around the metal connects, is this normal? and is there anything else i can do?! thankssss again for the help
Old 06-29-2011, 02:38 PM   #4
HTR SUB1 is only on Yaris with the supplemental heater, so some don't have it.
The black is normal on the base of the contacts. If you have a 9 volt battery on hand you can touch it to the two contacts on the left side of the picture below. When you do so the relay should click.
