Old 06-29-2011, 05:04 PM   #1
aznofmuff
Drives: yaris08
hey scott yeah it does click when the ignition is turned on. what should i check next/!?!! many thanks yet again!!
aznofmuff is offline   Reply With Quote
Old 06-29-2011, 05:33 PM   #2
Is that one clicking when the key is turned to "START" or is one clicking when it is turned to "ON"?
If that one is definitely the clicking one, then the next thing to try is to pull the relay and using a piece of wire, jump the other two contacts on the relay socket (other two from the ones that you touched the battery to above). Don't fully insert the wire in to the two terminals, but rather just touch it between them,
When you do so, it will make a good spark and theoretically the starter should spin.
Old 06-29-2011, 05:47 PM   #3
aznofmuff
Drives: yaris08
stil nothing... i put the wire across and started the engine but it doesnt wanna do anything... is there anything else u can recommend?! thanks again
Old 06-29-2011, 07:41 PM   #4
With the relay out, measure the voltage between each of those terminals on the relay socket and the negative post of the battery.
Also measure the voltage between the huge wire on the stater and a ground (like the engine block).
