Old 07-09-2011, 12:05 AM   #1
To install an AFR gauge with sensor, you need to drill and tap, or weld a bung onto the down pipe to mount the gauge's sensor.
I am using NGK Iridium 1X plugs (BKR7EIX-11), which is what Cammell used with it. Iridiums are pre-gapped and aren't supposed to be adjusted, so I left them at their 1.1mm gap (which actually meets the OEM gap spec of 1.0 to 1.1 mm)
Old 07-09-2011, 12:25 PM   #2
Focus_Sh1ft
Focus_Sh1ft's Avatar
You should absolutely have a boost, AFR, and water temp gauge when going FI. You're gonna need something to read codes as well, otherwise you're left guessing. I'd grab an oil pressure gauge as well. I know it's tempting to cut corners, but you can't be too safe when it comes to monitoring an engine converted to FI.
Old 07-09-2011, 06:51 PM   #3
MGargano
Drives: 2009 Yaris Hatchback
Well I have the Scangauge II, which displays water temp and oil pressure, right?
Old 07-09-2011, 01:15 PM   #4
^ You don't have to weld a bung if that's a problem in your area. AEM has a solution for that.
http://www.aemelectronics.com/no-wel...unt-2-inch-660
Old 07-09-2011, 06:54 PM   #5
MGargano
Garm that's perfect, thanks! I'm not sure where to tap for the AFR, but if it's in the mid-pipe, mine is 2.25" and that looks like it only goes as wide as 2".
Old 07-09-2011, 07:53 PM   #6
The AFR sensor needs to go somewhere before the cat.
BTW, the scangauge can't measure oil pressure on the Yaris, since it just has an oil pressure switch, as opposed to a pressure sensor.
Old 07-09-2011, 08:57 PM   #7
MGargano
Gotcha. So AFR, possibly boost, and an oil pressure gauge then. Can I mount on of those A-pillar gauge pods on a car with SRS stamped on the OEM A-pillar?
Old 07-09-2011, 11:30 PM   #8
You can mount on the A pillar. The airbag isn't actually under the pillar. The reason for the special clip with "SRS" on it is to keep the A pillar cover from becoming a projectile when the curtain airbag pops next to it.
Old 07-10-2011, 01:11 AM   #9
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
http://www.customgaugepod.com/
Nathan will do you right if you wish to have someone do the work. My pillar is actually on his website. (Adrian)
Tell him that I sent you. If you have him fabricate your pillar he is quick and he will also refab your passenger side so that it matches the driver's side which is a really nice touch.
Old 07-10-2011, 01:16 AM   #10
MGargano
So he actually molded the pods into your existing A-pillar? That's pretty cool. I'll definitely get in touch with him. Thanks.
Old 07-09-2011, 10:23 PM   #11
they have 4 or 5 sizes to pick from, each one is for a range of diameters. I can get you the part if you want one.
Old 07-10-2011, 01:17 AM   #12
fnkngrv
fnkngrv's Avatar
^ Yes he does. I will take an "inside" pic for you tomorrow and PM you so you can check it out. I also edited my post.
Old 07-10-2011, 01:19 AM   #13
MGargano
Great, thanks
Old 07-10-2011, 05:04 PM   #14
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
I have a vacuum/boost gauge, wideband AFR, and oil pressure gauge. I went to a muffler shop and had them weld a bung for the AFR sensor. I'll send you pictures of the ghetto dash setup. :)
I just replied to your PM.
Old 07-10-2011, 05:27 PM   #15
MGargano
Thanks, Noogie. I ran into some serious problems after the install was complete, so unfortunately gauges are the least of my worries right now.
With the boost on or off, the car will not stay running unless I keep my foot on the throttle. If I let off the throttle, the RPMs nose-dive and the car stalls. When it is running, it sounds like it's sputtering/coughing/choking, like it's not getting enough gas.
CTScott has been helping me troubleshoot via PM, but no luck so far.
I checked and re-checked the throttle body, vacuum lines, and injectors and also put my old spark plugs back in and there was no change.
There was also no change when I disconnected the fuel controller, eliminating the electrical portion of the supercharger.
I'm at my wit's end, without a car, and ready to spend another whole day ripping this thing back out and praying that solves the problem, unless anyone else has a suggestion?
I'm also not sure if there's a professional place in the Central/Shore NJ area I can even take the car to, to have them diagnose and possibly repair the problem.
Old 07-10-2011, 05:51 PM   #16
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
hey i tried to PM you this, but your inbox is full. Not to spam but...
you might want to go on www.microimageonline.com and post your problems on their forums. they have some members there that might be able to help you that dont come on this message board. as far as for me, im not sure what the problem is either. sorry
Old 07-10-2011, 05:54 PM   #17
LtNoogie
LtNoogie's Avatar
Do you have a vacuum leak somewhere? I remember from years ago that my old Chevy would idle very rough due to a vacuum leak. It would only run when the throttle was pressed down.
Old 07-10-2011, 05:55 PM   #18
MGargano
I don't think it's vacuum. I think I would hear some kind of hissing sound if that were the case, right?
blitz s/c tropicalrs Forced Induction Forum 7 10-03-2011 10:32 AM
Blitz S/C a rebuilt and rebaged Toyota S/C? Yaris0609 Forced Induction Forum 3 03-13-2010 01:21 AM
old article about blitz s/c but interesting info.. AdeJong 03 Forced Induction Forum 4 09-18-2009 03:08 PM
fixed my blitz s/c problem for now laszlo Forced Induction Forum 3 04-19-2009 11:24 PM
Blitz S/C on 08 Yaris whooppee777 Forced Induction Forum 12 11-26-2008 02:45 PM
