Old 07-07-2011, 06:37 PM   #1
ecc_33
ecc_33's Avatar
Drives: 2008 toyota yaris
Most electronic parts such as starters and altenators for toyota are all made by denso which is a really good quality part. Lot better than bosch and some of the other manufactures. Which is also why they typically cost more even for a remand. You say the voltage is at 14.1 which is no indicator that the altenator is bad. Most cars range from high 13.5-14.0 Also when you rotate the pulley for the altenator there is going to be a slight resistance its not going to spin like a idler pulley. Actually its more likely a idler pulley would go bad first. What i would do is with the belt removed start the car and see if the sound is gone 100 percent then you know for sure its an accessorie thats causing your sound.
No, the old alternator went from charging day in and day out 13.80v to 14.2+ volts when the noise came. 100% sure it was the alternator bearing. I then took it to a electric motor/alternator repair shop and he said the stator went bad. With the new alternator on the car is back to normal, sound and volt out put
08 toyota yaris with some big tires lol
02 chevy duramax that runs 11.63 at 116 mph in the 1/4 mile
ecc_33 is offline   Reply With Quote
What do you guys use to clean dust? JerseyJeff84 DIY / Maintenance / Service 13 03-30-2011 01:37 AM
Dust sucked in everywhere! Dylan DIY / Maintenance / Service 2 10-25-2010 02:10 PM
WTB:OEM rear shock dust covers with bumpstops DeathBeard Willing to Buy by private party 0 09-02-2010 12:16 PM
set in cement dust centrysis Wash, Wax, Detailing, Exterior Repairs 6 07-01-2010 07:45 PM
EBC Rotors/PADS CorSport CorSport 0 07-10-2009 07:30 PM
