Old 07-09-2011, 02:02 PM   #1
ktb973
Drives: 2007 yaris s sedan
Yes the light does come on. I've found the manual for the ac.
http://www.etimago.com/yaris/repairm...nditioning.pdf
I haven't dug into all of the electrical yet, just the basics so far such as fuses, low pressure switch voltage and voltage to the compressor. Pressure switch was fine but that voltage to the compressor was under 3 volts.
I am capable of tracing it all out if it sounds electrical to you guys. I was just wondering if it's something simpler that I don't know about.
Thanks
ktb973 is offline   Reply With Quote
Old 07-09-2011, 03:13 PM   #2
Thanks
If the light is on, then the AC Amplifier (ECU) is alive (and the A/C fuse is good). At this point, it would be ideal to be able to read the DTCs from the AC amplifier, but unfortunately that particular ECU will only report its DTCs via the Toyota TechStream tool.
So, I would verify the voltages on the pressure sensor and the evaporator temp sensor, and if they are both OK, I would probably opt to have someone plug in a TechStream tool.
It would be nice to be able to plug it into a Toyota Techstream
Old 07-09-2011, 03:30 PM   #3
ktb973
I have a code reader from mac tools. Think that will tell me anything? I'll try it anyway. The only reason I haven't yet is that it was in my car that my wife is driving now.
Old 07-09-2011, 03:33 PM   #4
No. It would have to support the Toyota diagnostics protocol, as opposed to OBDII.
Old 07-09-2011, 07:50 PM   #5
ktb973
Thank you for your help. I think I will just take it in rather than going down a rat hole trying to diagnose it myself. It does seem like an electrical problem I suppose.
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 05:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 10:17 PM
Yaris A/C Efficiency ArtS General Yaris / Vitz Discussion 7 06-19-2011 03:16 AM
A/C Broken On My 2010 5 DR HB ChilliwackGuy DIY / Maintenance / Service 15 07-14-2010 05:33 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 09:53 PM
