Old 07-09-2011, 02:14 PM   #1
spiceyhotwings
Drives: 2009 Yaris RS 5 door
My fog light connector looks different than the one in the pic or it seems
that I can't find one that looks like that.
My connector has 2 signal and 2 fog light pins on the top row.
It has 2 parking lights and I believe 2 side marker pins on the bottom row.
It might be the same as the one in your yaris.
my new 2009 Yaris RS 5 door
spiceyhotwings is offline   Reply With Quote
Old 07-09-2011, 02:35 PM   #2
That's not the fog light connector that I am showing, it is the headlight stalk connector. Does you Yaris have the foglight switch on the tip of the stalk or is it a separate console mounted switch?
Old 07-09-2011, 02:43 PM   #3
spiceyhotwings
Where does one find this headlight stalk connector?
I might not be looking at the right spot.
My fog light on/off switch is on the signal arm just to the right of the low/high beam toggle.
All the functions seem to be on that one arm.(signals,high beam on, low beam, fog on/off switch, parking lights.)
Old 07-09-2011, 02:47 PM   #4
That's the "arm" or "stalk" I am talking about. Follow it down to under the steering column cover and you will find the connector. There are three screws that you have to remove to remove the lower steering column cover. Two are under the steering wheel (rotate the steering wheel about 45 degrees in either direction and you will see them). The thirds is next to the lever for adjusting the steering wheel height.
Old 07-09-2011, 05:08 PM   #5
spiceyhotwings
Hi....I tried doing this and it didn't work. I hooked everything back to normal and am going to settle with the factory setting.
The only problem now is I think I blew the fog light fuse, because my fog lights don't work now.
I can't seem find the fuse box that houses the fog light fuse.
It's not in the one under the hood and my manual says it's under the instrument panel, but I can't find the fuse box.
I will be happy just to find the fuse box and get my fog lights working again.
Could you please give me any advise on how to find this fuse box.
Old 07-09-2011, 05:16 PM   #6
That definitely should have worked if you understood my directions.
The FOG fuse is in the under dash fuse panel, literally under the bottom of the dash behind the lever that opens the hood.
Old 07-31-2011, 02:21 AM   #7
formulation
Drives: 2010 Yaris 4dr LB Blazing Blue
Just to be clear, by cutting the wire in pin 4 of the headlight stalk connector and capping off the harness end of the wire, this wire is just removed from the circuit. Then tapping (splicing) the end of the cut wire from pin 4 to the wire in pin 13 will allow them to turn on with the parking lights, low beams or high beams.
Thanks
formulation is offline   Reply With Quote
Fitting Front Fog Lights OEM - Yaris 2007 3dr weller Cosmetic Modifications (Exterior/Interior) 1 12-17-2009 12:29 PM
Need some help with Fog Lights on 09HB Pikachu DIY / Maintenance / Service 1 07-06-2009 01:40 PM
Sedan Fog Lights, few questions!(where to get) ( make into HID Fog Lights!!!) Lafiro Cosmetic Modifications (Exterior/Interior) 2 06-12-2009 03:56 PM
My ebay fog lights and led interior light pics Julz Photo-Video-Media Gallery 6 09-13-2007 10:41 AM
Disabled DRLs and Factory fog lights DARKYARIS DIY / Maintenance / Service 21 05-01-2007 05:32 PM
