![]() Drives: 2009 Yaris RS 5 door Join Date: Dec 2008
Hi....I tried doing this and it didn't work. I hooked everything back to normal and am going to settle with the factory setting.
The only problem now is I think I blew the fog light fuse, because my fog lights don't work now. I can't seem find the fuse box that houses the fog light fuse. It's not in the one under the hood and my manual says it's under the instrument panel, but I can't find the fuse box. I will be happy just to find the fuse box and get my fog lights working again. Could you please give me any advise on how to find this fuse box.
my new 2009 Yaris RS 5 door
#2 | |
That definitely should have worked if you understood my directions. The FOG fuse is in the under dash fuse panel, literally under the bottom of the dash behind the lever that opens the hood.
![]() Drives: 2010 Yaris 4dr LB Blazing Blue Join Date: Jan 2009
Just to be clear, by cutting the wire in pin 4 of the headlight stalk connector and capping off the harness end of the wire, this wire is just removed from the circuit. Then tapping (splicing) the end of the cut wire from pin 4 to the wire in pin 13 will allow them to turn on with the parking lights, low beams or high beams.
Thanks |
#4 | |
Is this a fuse?
http://www.toyota-tech.eu/aimuploads...01%20190-1.pdf Do you know if the part (N) on page 7 of 35 is a fuse? I fried my fog light relay and have checked all the fuses and still can't get them to work. I was wondering if part (N) was a fried fuse and if I replaced it would it get my fogs back running. If that doesn't work I was planning to put in a new aftermarket relay system.
#6 | |
yes it does have DTL.
| Fitting Front Fog Lights OEM - Yaris 2007 3dr | weller | Cosmetic Modifications (Exterior/Interior) | 1 | 12-17-2009 12:29 PM |
| Need some help with Fog Lights on 09HB | Pikachu | DIY / Maintenance / Service | 1 | 07-06-2009 01:40 PM |
| Sedan Fog Lights, few questions!(where to get) ( make into HID Fog Lights!!!) | Lafiro | Cosmetic Modifications (Exterior/Interior) | 2 | 06-12-2009 03:56 PM |
| My ebay fog lights and led interior light pics | Julz | Photo-Video-Media Gallery | 6 | 09-13-2007 10:41 AM |
| Disabled DRLs and Factory fog lights | DARKYARIS | DIY / Maintenance / Service | 21 | 05-01-2007 05:32 PM |
