![]() Drives: yaris liftback 2007 Join Date: Dec 2009
the blue wire have +12v when i release the clutch in link with the white wire?
because i don't have any power on my clutch switch. my wire are clutch switch +/- to fusebox (white and blue wires ) |
Correct - When the clutch is not pressed the blue gets 12V from the white and when it is pressed it opens and the blue has 0V.
and this cruise control have a fuse anywhere, in case of shortcut ??
what's happen if utilise N.C switch for testing purpose? in exemple the first switch are N.C (pin 40 to this switch) , and for the second switch i utilize an N.O switch? the n.c switch when i push on it its "ON" when i repress on it its "off". and the second switch its "set" |
#4 | |
A NC switch won't work. The ECM expects to see the input float and then get pulled down to a specific voltage range for it to register. I have reverse engineered the Toyota diagnostics CAN Bus comm to read the cruise control switch state from the ECM, so I can watch how the ECM responds to the inputs. Have you measured your resistors to see exactly what they read resistance wise. Sometimes you can get a batch that are really at the end of their tolerance band.
i don't know what is the way to test resistors...
12v on a side of the resistor and read the other side? |
Resistance setting on the multimeter. Measure with no voltage applied.
| Cruise Control Available for 06/07 Yaris | TOYOTaejien | General Yaris / Vitz Discussion | 8 | 08-27-2010 12:58 PM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
