Old 07-10-2011, 10:20 PM   #1
i-trans
Drives: yaris liftback 2007
and this cruise control have a fuse anywhere, in case of shortcut ??
what's happen if utilise N.C switch for testing purpose?
in exemple the first switch are N.C (pin 40 to this switch) , and for the second switch i utilize an N.O switch?
the n.c switch when i push on it its "ON" when i repress on it its "off".
and the second switch its "set"
i-trans is offline   Reply With Quote
Old 07-10-2011, 10:26 PM   #2
No fuse - This is just an analog input to the ECM.
A NC switch won't work. The ECM expects to see the input float and then get pulled down to a specific voltage range for it to register. I have reverse engineered the Toyota diagnostics CAN Bus comm to read the cruise control switch state from the ECM, so I can watch how the ECM responds to the inputs.
Have you measured your resistors to see exactly what they read resistance wise. Sometimes you can get a batch that are really at the end of their tolerance band.
Old 07-10-2011, 10:29 PM   #3
i-trans
i don't know what is the way to test resistors...
12v on a side of the resistor and read the other side?
Old 07-10-2011, 10:32 PM   #4
Resistance setting on the multimeter. Measure with no voltage applied.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
