Old 07-11-2011, 10:37 AM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
If you look on the wiring diagram there should be two wires for the MAF. One takes the signal from the sensor and the other one sends it along to the stock ECU.
So what happens is the fuel controller sees the signal before the computer does and adjusts the signal. If you have it wire in backwards the signal won't be going in the right direction.
Double check that, or just reconnect the MAF to the ECU bypassing the fuel controller and see if that solves the problem.
Old 07-11-2011, 11:02 AM   #2
MGargano
Drives: 2009 Yaris Hatchback
I keep staring at the wiring diagram and I'm still not sure which wire you're talking about, but it sounds like this one could be the problem, so I'm eager to try it. I'm also not sure how to reconnect the MAF to the ECU and bypass the controller.
http://www.blitzpowerusa.com/techsup...ingdiagram.pdf
MGargano is offline   Reply With Quote
blitz s/c tropicalrs Forced Induction Forum 7 10-03-2011 09:32 AM
Blitz S/C a rebuilt and rebaged Toyota S/C? Yaris0609 Forced Induction Forum 3 03-13-2010 12:21 AM
old article about blitz s/c but interesting info.. AdeJong 03 Forced Induction Forum 4 09-18-2009 02:08 PM
fixed my blitz s/c problem for now laszlo Forced Induction Forum 3 04-19-2009 10:24 PM
Blitz S/C on 08 Yaris whooppee777 Forced Induction Forum 12 11-26-2008 01:45 PM
