Old 07-11-2011, 11:13 AM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
OK, VG is you MAF wire. It doesn't look like it's an inline interrupted signal. The controller just looks at the signal and adds more fuel.
Last thing I can suggest then, if you're sure all the wires are in the right spot, is to do a continuity test with an ohm meter on the connections. You can use a small sowing needle to back prob the pins on the ECU. Make sure the connections are all reading 0 ohms.
Edit, Have you tried running the car with the fuel controller disconnected?
Old 07-11-2011, 11:26 AM   #2
MGargano
Drives: 2009 Yaris Hatchback
I just disconnected the fuel controller (cut all wires and yanked it out) and still having the same issue
blitz s/c tropicalrs Forced Induction Forum 7 10-03-2011 09:32 AM
Blitz S/C a rebuilt and rebaged Toyota S/C? Yaris0609 Forced Induction Forum 3 03-13-2010 12:21 AM
old article about blitz s/c but interesting info.. AdeJong 03 Forced Induction Forum 4 09-18-2009 02:08 PM
fixed my blitz s/c problem for now laszlo Forced Induction Forum 3 04-19-2009 10:24 PM
Blitz S/C on 08 Yaris whooppee777 Forced Induction Forum 12 11-26-2008 01:45 PM
