Old 03-03-2007, 07:53 PM   #1
Black Yaris
der Zeck
Black Yaris's Avatar
Originally Posted by HTM Yaris View Post
I put the sportivo struts on my car in conjuntion with the STOCK springs . Holy shit , fudge ,dayyummm with a little shizzle on the top :):):) I also added 195/50/15 mounted on gold konig feathers 15x6.5 . The car feels like it is on rails . The car is definately quicker (0-60) . Going over railroad tracks @ 40+ mph , no problem . Nice and tight . Body roll is SIGNIFICANTLY reduced . Also , when a 18 wheeler blows past me on the interstate , I don't get pushed as much .
My Yaris won HS @ the Autox last week on the stock shocks . On Mar 17 ,I'm gonna see how much distance I can put on my 10 other competitors . :)
All hail the mighty EGG :)
One last thing . The 195/50's are Michelin Pilot Exalto's PE2 . Treadwear of 240 . Nice , very nice . I have'nt got them to sing yet though , but I will let ya'll know :)
You may think your car is quicker since you are running such a small tire
exactly your speedo is 4.725% faster than actual speed
also that tire is a full inch shorter than stock, I hope you do not have ABS because that much of a difference from stock may cause some brake problems
Old 03-03-2007, 08:13 PM   #2
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Yes I have EBD on the brakes . It doesn't matter what size the wheels are where the brakes are concerned . Lockup is lockup . When lockup is eminent , the computer will act accordingly . Toyota isn't that stupid . They know that peeps will change wheels/tires and other things . Toyota probably did the conservative thing and used wide parameters when calibating the EBD .
Old 03-04-2007, 12:39 AM   #3
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
It won't cause any problem. In fact his braking has IMPROVED because he has a better tire with more traction. Tires are the most important factor in stopping the car. THe more traction you have, the harder you can stop without lockup.
holy sexy clutch birdy General Yaris / Vitz Discussion 8 05-05-2006 08:34 AM
