Old 03-04-2007, 12:39 AM   #1
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
You may think your car is quicker since you are running such a small tire
exactly your speedo is 4.725% faster than actual speed
also that tire is a full inch shorter than stock, I hope you do not have ABS because that much of a difference from stock may cause some brake problems
It won't cause any problem. In fact his braking has IMPROVED because he has a better tire with more traction. Tires are the most important factor in stopping the car. THe more traction you have, the harder you can stop without lockup.
holy sexy clutch birdy General Yaris / Vitz Discussion 8 05-05-2006 08:34 AM
