Can the Yaris run on E85? Anybody try it?
The local Valero gas station by me sells E85 for like a buck cheaper than "real" gas.
Can the Yaris run corn juice????
Never take eyes off opponent - Bruce Lee |
![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
E85 is costs less, but cars running it get FEWER MPG than regular gas...
pretty sure you have to have a "flex fuel" vehicle to run it but as previously stated your mileage will not be the same. it all evens out in the end.
if you have a vehicle that is made for it, I think it does better but it has to be made to run the stuff. not 100% but that is what I think |
Sounds like a waste of corn/food!
I was also curious to see if the yaris fuel system could handle it without being damaged.
This is a good Q and A on E85. The main reason you "can't" use it in the Yaris is that the ECM isn't programmed to deal with the difference in target AFR required to use it. Also, it's not quite as economical as you might think, since if you added a piggyback (and larger injectors) to tune for it, you would use about 30% more E85 fuel.
http://www.howstuffinmycarworks.com/...E85_fuel_.html
![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
If I recall right, the injectors cannot handle the e85 and also since there is
so much alcohol content in that stuff, it'll eat/rot out your fuel lines like no other.
I live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important. |
That turns out to be a fable. Vehicles built since the early 80's use rubber and plastics that are not susceptible to alcohol. The biggest concern with E85 is its ability to absorb water and hence corrode ferrous metal parts.
Enthanal use should be shunned by all consumers! Dont encourage these a holes by buying their crap!
I've driven my Yaris in 45 states and in some states the octane rating for the standard grade unleaded is 86 instead of 87. My car has never run differently to any noticeable degree after such fill ups and I've never had any fuel related part fail. However, re 85 octane gas, the previous posters on this thread could easily be correct.
^ Hes not talking about 85 octane, but E85, i.e. a fuel blend that is 85% ethanol from corn or other biomass...
It's interesting to note that a lot of tuners seem to use E85 as a cheap alternative to race gas, since the octane rating is comparatively high... and they're not too concerned about mileage :D
return of the comeback
Drives: white '08LB..very nice,i like Join Date: Mar 2007
so i guess no one hasn't used E85 yet huh?
any update OP? this might help http://www.change2e85.com/servlet/Page?template=Myths i would do the conversion... if i had money.. hehe.. http://e85prices.com/california.html at the lower right corner of the page, there's a calculator.. unless someone has done actual mpg calcs on their yaris, we can only assume, that even with a 10-15% reduction in mpg, E85 is still a good deal..
Everything will be ok in the end... if it's not ok, it's not the end. 93 Civic Si- SC/B18B1 - street beast 07 Red/BlackTop Yaris LB - died in a sandwich in 2010@168K. 08 White Yaris LB - daily beatnut...round 2! |
#12 | |
2ZR swap. DO IT! Ask how!
It's very hard to come up with something that can rival the energy density of petroleum based fuels. The fact that they can get as close as 70% from fermenting corn is pretty impressive. |
#13 | |
Only Happy When it Rains
Adding ethanol to gas makes it both more expensive and get worse gas mileage. It is a total disaster to everyone that does not sell corn for profit.
Colin Chapman disciple |
#14 |
E85 on a boosted 1nz would be
The only way to go. Yes, your target AFR is richer on E85, but you can make a lot more power per psi of boost simply because E85 has a much higher octane rating than even "premium" fuel, which allows you to gain back those timing retards you had to do on regular pump gas. Long story short, boost and E85 are a GREAT combo.
#15 | |
#16 |
![]() ![]() ![]() Drives: yaris hatch 07 640K original m Join Date: Mar 2007
I have used it many times in South Dakota area and no problem. There is usually a gallon of regular gas when I put it in.... no sweat.....the alcohol should clean injectors a little bit.
btw 310K on my 07 Yaris hatch. NO BULL |
#17 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
Nope. Modern flex fuel car fuel lines are different composition than normal E10 fuel lines.
#18 |
![]() ![]() ![]() ![]() Drives: 2013 Yaris Join Date: Oct 2011
i recently saw a gas station that stated their premium had no ethanol in it...my tank was full, else i would have filled up with it and seen what the difference was.
| Yaris vs MR2 Spyder | regal | Off-topic / Other Cars / Everything else Discussions | 36 | 01-25-2026 12:56 PM |
| I think I was being made fun of for driving a yaris (or my yaris) last night.....hehe | PETERPOOP | Off-topic / Other Cars / Everything else Discussions | 21 | 05-16-2010 03:19 PM |
| New Yaris 5 DR HB arriving April 5, 2010 | mkorejwo | New YARIS Purchase Forum | 6 | 04-06-2010 11:39 PM |
