Old 07-20-2011, 07:01 PM   #1
Just for comparison, I'm on Tein S.Tech's with 205/40/17 tires on a 17x7.5 rims with an offset of +38. They rub the fender liner up front, no biggie. I also have 10mm hub spacers in the back, and the tires rubbed pretty bad before I rolled the fenders and put in some coil lifter/spacers.
Old 07-21-2011, 04:44 AM   #2
JTDBT903
JTDBT903's Avatar
Drives: '08 SEDAN 5 SPD.
I always wondered why you had such a level stance!
Can you tell me any more info about the spacers?
I have the droopy ass syndrome and have about a 1/2'' difference between the front and back. I thought about cutting the front springs but I rub a little on highway dips, I'm on 195/55/16 on Mini Cooper rims.
JTDBT903 is offline   Reply With Quote
Old 07-21-2011, 03:13 PM   #3
I'm using the block style spacers. Some have either disintegrated or fallen off.
I'd recommend the collar style spacers instead. You can look here for the rears (or remove "rear only" in the option if you want to find some for the fronts as well).
http://www.summitracing.com/search/D...y/?Ns=Rank|Asc
The blocks I have have two settings, I'm using the smaller setting. It barely raises the rear, and I'm mainly using them to prevent full compression of the suspension since I'll rub if it can full compress
Old 07-22-2011, 07:44 AM   #4
JTDBT903
JTDBT903's Avatar
Kaotic.
I never thought anybody was using the collar type.
It looks like all those are for rear wheel drive cars but I have seen some on E-bay for Yaris.
Old 07-22-2011, 01:33 PM   #5
Kaotic.
I believe jpadua on here is using the collar type. Shoot him a PM to confirm.
