Old 07-21-2011, 02:04 AM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
Originally Posted by Bluevitz-rs View Post
The A/C will cycle on and off to maintain a temp range preset by the system at the condenser. It doesn't matter what you set the temperature at because the system heats the air after it's cooled. The higher you set the fan the faster it warms the condenser and the more the system has to cycle to keep cooled, so you use more fuel.
That's really helpful. Thanks
On the other hand, in winter you dont use the compressor for heat. Does cranking up the fan or turning the heat dial changes fuel efficiency?
Old 07-21-2011, 11:19 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Sorry didn't really read this post...
If you have the defrost on the A/C is running all the time. In the winter it will still cycle if the condenser gets warm enough.
Running the heat will only effect warm up time in the winter, which greatly effects millage. I usually don't turn the fan on until the blue light turns off and even then only on low until the car gets up to about 160°. (I have a gauge)
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
Yaris A/C Efficiency ArtS General Yaris / Vitz Discussion 7 06-19-2011 02:16 AM
A/C Broken On My 2010 5 DR HB ChilliwackGuy DIY / Maintenance / Service 15 07-14-2010 04:33 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 08:53 PM
