Old 07-28-2011, 07:33 AM   #1
Cap
Drives: Toyota
14.7 is Good.. That is what you should have.. 14.6 is Fine too.. where was this Reading Taken.. Before or After the Cat.. The only difference After Cat is the Reading will be Dampened.. and the Dithering will be Gone.. Before Cat is REALLY hard to read.. as it always Moving..
Your Lean Code Lite is not really saying the Car is running Lean .. It's saying that it's having to add too Much fuel to get it back to 14.7, from where it should be..
The Danger is Lean at WOT.. If you have a LTFT of < Say> + 22.. This will toss a Cell at you,( lean Code ) and will still run 14.7 on the Road.. But at WOT it MIGHT not be able to Keep the Mixture above 13.5, as the Fueling Choices are done based upon How much Fuel it had to Add During Closed Loop.. and when in Open Loop and the Fuel Trim is past about 15.. ( Plus or Minus ) the Fueling gets Weird..
A Cell will be tossed when the LTFT gets Greater than 20 either + or Minus..
If you can Check WOT fuel Mixture ( Veh Mounted Wideband ).. and the Mixtures are in the Low 13's your good to go.. However.. if the ECU is tossing you a Cell because the LTFT is greater than 20.. chances are you MIGHT be lean at WOT.. Check Them
If you are at 14.6.. chances are you do not have an Exhaust leak.. ( If you were at 14 or richer I say Yes.. ) and the O2 Sensor/ Exhaust Leak is the Problem.. Looks like it is Not.. as the Fuel Mixture is Proper for Closed Loop
Put the Stock Intake back on.. Leave the Exhaust alone.. as it will not affect the Fuel Trims.. Do a few runs on the Old Intake.. ( Engine Cycles from cold to Hot . ) then look at the Fuel Trim.. Long and Short..
If the Long or Short are Greater than 5 each then you Likely have a Plugged Fuel Injector.. Either Swap them out.. or Pull them and Get them Cleaned..
IF the Fuel trim DO settle in the less than 5 Range ( 7 is ok Too ) then I say Something is Up with the Intake.. Either it's too Ruff inside causing a Bad Read.. or the MAF mounting Surface is Mounter Crooked in the Tube.. or it's too big
Cell's and Mods Kinda go hand in Hand.. but if you can Keep Chasing them down. and Dont let them Kick your A$$. then the ECU really is your Friend..
Cap
Cap is offline   Reply With Quote
HELP! Have I killed some sensor? NO POWER AFTER Headers and Cold Air Intake pasapaca Performance Modifications 7 02-07-2011 09:58 PM
Cool HELP! Have I killed some sensor? NO POWER AFTER Headers and Cold Air Intake pasapaca Performance Modifications 0 02-05-2011 11:48 PM
