Oh, man.... I hope you did'nt drive around in the rain minus those plugs. Water will come right in through the floor. Everyone should check for these!
That is not the case, it is open to the inside of the rocker, not the inside of the car.
nothing will happen.. maybe some wind noise under certain conditions like a whistle or sound when you blow in an empty bottle. Dealer is suppose to put those in when they come off the truck. but sometimes they are missed. U can install them yourself
#4 | |
![]() ![]() Drives: yaris hatchback Join Date: Jul 2011
are there space/hole infront of the rocker, where water can enter? if it's a tight hole, so better to lubricate it with wd-40 or oil to prevent that from rusting ? moisture might cause it to rust?
| MY RUBBER BAND BALL! AGHHH!!! | Sodium Duck | Off-topic / Other Cars / Everything else Discussions | 47 | 03-06-2009 01:56 AM |
| rubber protector sheets? | enobmort42 | Cosmetic Modifications (Exterior/Interior) | 0 | 02-25-2009 10:41 AM |
| source for intake coupling rubber boot. | andruboz | Performance Modifications | 5 | 01-23-2009 03:30 PM |
| Rubber plugs in glove box | cfiimei | DIY / Maintenance / Service | 5 | 01-06-2009 04:48 AM |
