![]() ![]() Drives: yaris hatchback Join Date: Jul 2011
The Vanishing Coins ...
What a good Toyota design!! Well, I place some coins in the center console - drivers pocket of my new yaris. Viola!! It fall beneath the console.... now my problem, how to get those coins??? Any idea? Suggestion?
Mr. 155 and climbing
were they collectors?
You just need to remove the center console to get them. Unscrew the shift knob, remove the screw from the cup holder and pop the center console up. It's like a piggy bank - You collect the coins in there until you really need them, then you take it apart.
lol, i have this problem also.. went to grab a couple quarters, got my finger on them to slide upward and then all of a sudden they were gone... I was like "WTF?" haha.. scott is right though. follow his directions
#6 | |
Take a look at the "interior" section of the service manual
http://www.etimago.com/yaris/repairmanual/
#8 | |
are these coins will fall just on top of the carpet under the center console or will slip right under the carpet( w/c will be more difficult to retreived)? |
if you're unlucky they might slip under the carpet... but it's not too hard to peel away from the center console, if I recall there's a velcro strip holding both sides together up front, open that and just peel the carpet back...
I have the same problem, but be lucky when you get it any time!!!
it is awesome cause the Yaris LB is like a mobile couch...lol
There's coin slots in the driver's glove box in the HB's.
i had all my coins organized in there untill the first corner...... stupid design
#14 | |
that should be it, just lift from the back and pull the whole thing over the shifter :)
YOu might also want to remove the piece in front of the handbrake with the AUX port (you should be able to unclip the cables from the back to remove it completely)
#16 | |
tried to see the coins from the front side of the carpet..it's to complicated. i'll will try it again next time....
Bob
Drives: Yaris and Scion XD 5 spd BSP Join Date: Dec 2009
You really don't have to remove the wiring clips. Just take the whole piece off and leave it there. Take it off by hooking a finger under the hand brake handle where it goes over the plastic flat area that the switches are mounted, and lift it straight up. Pop! it comes off, and you can turn and angle the whole plate assy to lift the console part out without disconnecting any of the associated switch wiring. Much faster/easier than mucking around with the wiring. Less chance for mis-wiring when reassembling. It will be easier to remove the plate when the hand brake is in a lifted/applied position. You can see the outline of the switch plate, and the part that sticks in the little "slot" just below the hand brake handle (when the e-brake is not applied) is where you will lift up. It will take you less time to remove it than reading this!
Finally, a Toyota!
Note to self: When I pick up my yaris on Wed, do not put coins in it....lol
2009 Yaris, Base Model 9-17-2011 at 16K Miles |
| Lost coins... in console?? | xmun | General Yaris / Vitz Discussion | 14 | 11-07-2010 01:13 AM |
| Lost coins through centre control panel | Former_Neon | General Yaris / Vitz Discussion | 9 | 10-14-2009 01:38 AM |
