Old 08-09-2011, 08:41 PM   #1
Originally Posted by romram View Post
yap. put some coins, then when you try to get them, they slide underneath... can't find where they fell.... i hate coins under the dashboard assembly.... now, how can i remove them, to avoid possible damage to shifter/electrical area?....
You just need to remove the center console to get them. Unscrew the shift knob, remove the screw from the cup holder and pop the center console up. It's like a piggy bank - You collect the coins in there until you really need them, then you take it apart.
Old 08-09-2011, 09:20 PM   #2
romram
Drives: yaris hatchback
Thanks alot! BTW, any pictures what screws to remove(step by step)? it's a auto trans... i just want to be really careful, it a new car, don't want to crack those brittle plastics....or plugs/trims. Are there DIY topic re: disassembly of these , so I would just like to refer to them?
romram is offline   Reply With Quote
Old 08-14-2011, 11:14 AM   #3
romram
ok, i'll try to remove the center console. i will remove the screw from the cup holder & unscrew the shift knob. so what's next? are there other clips/screws?
Lost coins... in console?? xmun General Yaris / Vitz Discussion 14 11-07-2010 01:13 AM
Lost coins through centre control panel Former_Neon General Yaris / Vitz Discussion 9 10-14-2009 01:38 AM
