How Long Till It Blows?
Rutt Row.
26 months and 26k miles old. Did anyone get this but not have a total failure for a while? Coolant level is now and has always been "FULL" Cant see anything around the water pump. |
I hate waiting.
DON'T LIKE ME? TAKE A SEAT WITH THE REST OF THE BITCHES WHO ARE WAITING FOR ME TO GIVE A FUCK. Sponsored by: Micro Image http://microimageonline.com |
Take a mirror and angle it down to where you can see the inside of the waterpump pulley, bet it's pink and crusty in there. You do have the tell tale sign on the hood however.
I felt inside the wp pulley butthere ws no crust there. Im wondering if this could be stable for a lobg time?
Or will it suddenly let loose? |
id go ahead and start saving up now if your going to take it to someone else. Or just buy the new water pump and get it over with now. Its obviously leaking.
As much as I cannot stand anyone else monkeying with my car its under warranty until next spring.
It seems though I have heard stories about new (Toyota) pumps failing too. Perhaps I should go with after market? Also I work with engineers diagnosing complicated devices used in military and space appplications. (they design it I build it) So I am used to thiniking out of the box on things. Like: the splash looks old and there isnt a lot of it. Perhaps it just leaks a little once or twice and then it stops? Thats why I want to ask others: is failure inevitable at this point? Also I just drove 10,400 miles to Alsaka and back in 16 days. There were lots of days I was going 80 mph all day for 10 or 12 hours. Maybe that has something to do with it? Last edited by bronsin; 08-13-2011 at 08:22 AM. |
My 07 HB let go at just under 15K the beginning of this year. I replaced myself with a Toyota pump from a online discounter. Did the thermostat and fluid change at the same time. I think the issue was part my fault in that I might have overtightened the belt adjustment after replacing my pulleys. I'd clear the issue up.
Now that I think about it in Fairbanks AK last month before leaving for home I changed the oil and checked the air filter in the Walmart parking lot there. I also checked the hood for tell tale water pump stains.
There werent any. This has happened since then. I know people have changed pulleys etc and the thought is perhaps this has something to do with the pump failing? For the record I have no different pulleys and the belt has never been touched. And in my (35 years of) experience Ive never seen a maladjusted belt cause a waterpump to leak. My 2 cents. |
JOE GIRTH
Drives: YARIS 3DOOR Join Date: Feb 2007
pump failure IS NOT caused by afteermarket pulley/s as i am testement to that with factory pump and 50K still going strong. Toyota has a problem with once again outsourcing parts and this water pump failure goes beyond just yaris models....
http://www.carid.com/toyota-accessories/ site has a FEW interesting yaris items..... |
#10 | |
Thats why I wanted to ask if the aftermarket pumps are lastsing longer? I guess Im going to have T replace it cause its under warranty. |
toyota
covered by warranty 5 years/100k km...just had mine done by toyota leaked after 80k
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!! "Horsepower is how fast you hit the object. Torque is how far you move that object.." |
I hope that my statement ref pulleys brought this on. My only thing was to point out that because I put them on and maybe overtightened the belt that I may have contributed to the failure so therefore I repaired myself. All is well.
#13 | |
Now...two questions. If it fails OUT OF WarrANATY, how long is the repair covered for? I assume if its warrantied for 100k miles they fix it free no mstter how many times it fails? |
JOE GIRTH
which is why i made my statement of aftermarket parts not being a contributing factor....
resident senior
Maybe some road chemical that somehow got onto your belt and was slung upwards
![]() Did you check your AC ?
#16 | |
DAT'S RIGHT I GOTz 2
which is 5yr/80k mi or 60mo/100k km if it fail while its still under warranty the dealer has to change it no matter how many times it fails unless they find something that would cause it to fail prematurely which they would have to prove it if you change it through the dealer after warranty parts and labor should be covered by at least 12mo/12k mi the main problem why alot of newer car parts fail in due to the higher use of recycled material
#17 | |
JOE GIRTH
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 03:41 AM |
| Yaris - do you find it comfortable on long trips? | 360cubes | General Yaris / Vitz Discussion | 51 | 05-04-2009 01:31 AM |
| Golfers: Long, Long Par 3! | Benggolf2 | Off-topic / Other Cars / Everything else Discussions | 2 | 04-04-2009 04:57 AM |
| How long? Japan --> US | KittenRD | New YARIS Purchase Forum | 4 | 05-30-2007 08:13 AM |
