Old 08-15-2011, 01:26 AM   #1
andrewmcg
Drives: stock
Ok, using the picture below, you start by tightening down bolt #1 all the way so it wont budge. Bolt #2 is in stock location and needs to be loose. Bolt #2 is the one that moves with the alternator and moves as belt tightens or loosens. Now L brackets should be about 1" apart and you put bolt #3 in and start tightening. As you tighten #3, it pulls the alternator out towards the front of the car, also tightening the belt. Once you like how tight the belt is, tighten up bolt #2 and it will all stay there. Viola!
andrewmcg is offline   Reply With Quote
Old 08-15-2011, 05:15 AM   #2
bronsin
bronsin's Avatar
Ah thankyou. The brackets being together is what threw me off. I always need everything explained to me.
Speaking of that, what size is that angle iron? 3/4 inch?
Oh and I have an improvement! (subject to approval)
Welding the nut that the adjustment screw goes into to the angle iron will make adjustment easier.
And am I right you also need to drill holes in each piece of angle irion for the bolts going to the adjusting bracket?
Beautiful, simple, effective, cheap design!
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
Squealing Belt rossman DIY / Maintenance / Service 8 01-31-2012 01:58 PM
Supercharger Belt Slip Possible fix quemoto Forced Induction Forum 20 03-04-2011 02:55 PM
2010 Prius brake problems easy fix. best video ever! dinamix Off-topic / Other Cars / Everything else Discussions 6 03-14-2010 11:00 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 08:53 PM
