Old 08-20-2011, 02:12 PM   #1
Originally Posted by yuri2002 View Post
sorry scottCT, I don't know where is the connector with the sky blue wire? Can you show me a pic and tell me how I would measure the voltage? Thanks
The connector is the left one of the two that connect to the instrument cluster. You need to measure the voltage between the blue wire on the top right of the connector and a ground point (like the sheet metal on the left side of the picture). If your can't get your meter probe into the connector to touch the pin, which the wire is crimped to, you will have to stick something like a paper clip into the connector hole to touch the pin with. Put your meter on the voltage mode, and with the engine running take that measurement.
DIY: Braille Battery install texkid DIY / Maintenance / Service 39 02-19-2013 02:40 PM
Charging voltage for stock battery Vinceb DIY / Maintenance / Service 3 02-12-2011 12:10 AM
Fog lamps as back up low beams. ellenbetty General Yaris / Vitz Discussion 114 10-22-2009 03:40 PM
Installation of a Battery Isolator frostbitten In Car Entertainment + Electronics (audio / video / alarm) 3 10-07-2009 12:11 PM
