Old 03-07-2007, 09:44 AM   #5
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
This is how some cars do it. Your wheels do a great job securing the rotors. BTW- I would only use genuine Toyota brake pads. I learned the hard way. non-genuine pads will most likely squeal and there is nothing you can do about it. Even using liberal amounts of the anti-squeal compound will not help. Also, do yourself a favor and put some anti-seize compund on your lugnuts. It makes them go on and off so much better, and you will never have to worry about breaking off a stud. I have done this on all my cars. Makes rotating tires, etc a dream. http://www.amazon.com/Loctite-Anti-S...3279911&sr=8-2
This stuff is great for spark plugs too, just make sure you don't leave gobs, just a thin even coat is best. One jar should last a lifetime, unless you are a full time mechanic.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline   Reply With Quote
Wilwood Brake Set dngz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 42 06-23-2007 03:59 PM
big brake kit turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-13-2007 01:44 PM
brake lights KSIbucky Cosmetic Modifications (Exterior/Interior) 5 10-31-2006 11:16 PM
Changing drum brakes to discs? eTiMaGo Performance Modifications 5 09-25-2006 04:17 PM
Removing third brake light lightyearsgirl DIY / Maintenance / Service 8 08-06-2006 11:26 AM
