#163 |
Drives: 2007 toyota yaris Join Date: Dec 2010
putting a stock cluster,w/tach in a 2007 HB.
i would like to put the instrument cluster w/ tach, in a us spec, 2007 hatch back.
will the cluster physically fit, and how much of the wiring to the cluster would have to be re done? has any body tried this before? thanks for any help in this area. bob smith, ohio |
#164 | |
#165 |
hey guys! i just installed my tachometer yesterday!
special thanks to mr. CTSCOTT for the wiring suggestions! will post pic soon. orayt! next stop, suspensions! :))
Live, Laugh, DRIVE! |
#166 |
![]() Drives: Yaris lift back, red Join Date: Aug 2009
Tach is important to me. Hearing aids, and excess road noise make it impossible to hear the little hum of the engine.
#167 |
![]() ![]() Drives: 2008 Yaris 3dr Hatchback Join Date: Oct 2010
RPM check
Just installed my tach and wanted to compare RPM's to make sure it is accurate.
2008 3dr, 5 sp manual. Turning 3000 at 70 mph. 2500 at about 60. |
#168 |
That sounds right
Mine reads about 2800 @ 65mph in 5th Yours is callibrated/configured properly for a 4 cylinder. Last edited by RedRide; 04-09-2011 at 10:25 PM. |
#169 |
147K-Blue / 24K-Yellow
Drives: 2010 Ylw 3dr. AT(Blue-Wife's) Join Date: Mar 2011
Brainr4
There isn't much diff between the Auto and 5 speed, (I imagine thats why the epa guesses we'll get nearly the same) I'm running about the same "R's" with my auto...a drop to 3rd puts me at 4300+/- @ 70.
All Weather Package, Power Package, Cruise, WeatherTech Floor Mats. Altimax Arctic Winter Tires. Repair List: 1 new blower motor, making funny noise. @ 91K (Water pump @ 120K) Mod List: 1. Black tape on most of the annoying blue high beam light behind the lens. (thank you CTScott) |
#170 |
Thanks!
I didn't think I would be turning so much at 70mph. If we had a 6 speed gas mileage would be close to the Prius. Ha, I guess that is why they would never put a 6sp in the Yaris! |
#171 |
Just installed my tach, 3 3/4" Glowshift Elite 10 Colour. Behind the steering wheel with full access to the glovebox behind it c:
![]() [Taken with Nikon D3000 w/ 10.5mm Fisheye] |
#172 |
Not quite a noob
Followed this DIY, works fine. You can actually use any of the "top" row of the OBDII connector for ground.
#173 |
![]() ![]() ![]() ![]() Drives: 2007 Yaris manual dark silver Join Date: May 2006
why would you though when there's a body ground right there
7 Color Tach Fujita Intake Momo pedals Shift knob and boot. Full TRD SSK. Blitz exhaust Megan Lowering Springs (Next is DC Header) |
#174 |
Right where?
#175 |
There's ground right by your left foot. read the diy. why would you want to ground to a obd2 rather than a factory ground point
#176 | |
I did that out habit more or less as most all Toyotas have factory ground pont there. However, the OBD2 is closser so why not use it? |
#177 |
The factory ground is better. Why tap into a wire thats a foot away from a ground point? The factory ground is exactly that a ground its not a obdii point it has a purpose use it.
#178 | |
A tach is a very low current draw item and the OBD2 ground is more than adequate. Don't loose site of the fact that if you are getting the tach signal frome the OBD2 to begin with, it will also be good for the ground. All modern tachs use LED/low current lighting. Otherwise, it would be like runninng a perfectly adequate 24ga wire for an item's positve and then, runing an 8ga wire for the ground for example. There would be simply no need for a 8ga ground. Last edited by RedRide; 08-12-2011 at 09:29 PM. |
#179 |
Ruler of the free world
Drives: 09 Yaris 2D HB Join Date: Jul 2010
test tach signal?
I installed my tach today. The light works, but the tach doesn't.
![]() I know I have power and ground because I can test those with my test-lite. Is there any way to test the tach signal circut? I am useing the tan wire furthest to the left on the OBD connector, as shown in this thread. I get no lite with a test light on that wire, but my volt meter reads about 6.8v. |
#180 |
Never use a test light on a "signal". Test lights draw current and connecting one to an ECM signal could potentially damage the ECM.
That being said, it is hard without an oscilloscope to verify a pulsed signal.
| Liftback Spoiler Installation | Toddhata | Cosmetic Modifications (Exterior/Interior) | 25 | 08-09-2009 01:26 AM |
