![]() ![]() ![]() Drives: '08 LB, '07 WRX Join Date: Jan 2009
Belts are not preventative maintenance; change when cracked or damaged. The only exception to this, is if the belt is off anyway (IE: for water pump change or something) and the car has a lot of miles on it. In that situation, I'd replace it while its off just to save the labor.
Our 08 Yaris just rolled to 58000 today and is still on the original belt. |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
Belts are preventive maintenace items. If a belt fails at highway speeds, you run the risk of trashing the motor or at the very least, being stuck on the side of the road.
You can monitor belts and hoses to try and get the most out of them you can, but the goal is to replace them before they fail. |
#3 | |
| yaris timing belt | phenoyz | General Yaris / Vitz Discussion | 16 | 02-24-2015 02:05 AM |
| Man hits 1 MILLION MILES in Ford F-250... in four years!!! | Kal-El | Off-topic / Other Cars / Everything else Discussions | 6 | 10-30-2010 11:19 AM |
| serp belt 90916-02499 | yaris9876 | DIY / Maintenance / Service | 1 | 05-22-2010 10:06 PM |
