![]() ![]() Drives: 2010 5 Door Join Date: Jan 2011
Im not sure how well a hair drier will work. I used an oven at 200 degrees and i was still wrestling it apart. My suggestion is to remove the headlight from the car. Pull out all the bulbs, drain the excess water and blow hot air into the back of the headlight.
#2 | |
![]() ![]() ![]() Drives: 1987 Silverado Join Date: Jan 2010
#3 | |
![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
Try what AppleJacks said, get all the water out and blow hot air inside. Maybe do this indoors where it's not humid. Then once it's all clean, you could run a bead of silicone around the headlight between the clear cover and the black back. Also check that your bulb holders are sealed properly. They should all have o-rings around them, and NOT be easy to twist out of the light. Then the main headlight should have a large black rubber cover that seals around the base of the main bulb. |
| Sound when making a left turn (a water flow sound) | jimmydie | DIY / Maintenance / Service | 9 | 06-20-2013 05:35 PM |
| DIY Projector/HID (sedan) | Brian | DIY / Maintenance / Service | 145 | 02-05-2012 04:13 AM |
| How To Smoked Sedan Headlight -DIY | zulhizainL902S | DIY / Maintenance / Service | 26 | 01-14-2011 02:12 AM |
| 07' HB Water Accumulation in hatch | bobolinko | General Yaris / Vitz Discussion | 9 | 09-26-2010 02:55 AM |
| Glassylite Headlight Restoration Kit | TEHxFALLEN V1.2 | Photo-Video-Media Gallery | 1 | 07-03-2010 12:51 AM |
